I'm going to try and do this tomorrow. I've been searching the forum and doing reading about this and have a few questions.
1. Do you guys usually put the truck on a ramp to do this? Can it be done without a ramp? Or, can you just jack the truck up from under the differential and place jack stands under each side of the axel?
2. When lifting the front to get the pan out, what lift point are you using for the jack?
3. I've read where several guys say to use something called "the right stuff" instead of the seal all together when replacing the pan. I've also ready that you should use the seal but use RTV on the engine side. Some say to use RVT on both sides of the gasket.
4. Should I use RVT on all the bolts? I'm thinking not on the threads but on the underside of the top of the bolts to prevent leaking. Or, should it be used on the threads?
Also, would something like hylomar be preferential to RVT?
Sorry for the simplistic questions. I've never attempted anything like this before and want to do it right. Thanks!!
