1 - 3 of 3 Posts
Rear electric windows on 1996 TDi don't work , front ok power getting to the centre rear switches but not working. Isolator switch seems Ok
Could it be ecu ?
I hate electrics.
Also oil leak where oil cooler pipe meets oil filter housing, is this common
DiscoPilot said:
Tag your it pass it on... try this I haven't had a chance to do mine yet.
http://www.landroversonly.com/forums/showthread.php?t=5613
^^ I had the same problem, except the mechanics solution was not to replace the ecu, but he directly wired the system to electricity, because he did that, my car doesnt turn off until you open the door ( after you take out the key)..
1 - 3 of 3 Posts
