1 - 4 of 4 Posts
01 disco 2. I had to replace the radiator core support and had to bleed the ac in order to get it off. Everything got put back together right, but when going to start the vehicle i ran into this problem. Ran fine prior to radiator core support replacement. I borrowed an obd reader from the auto parts store and it reads "No Powertrain DTC's or Freeze Frame Data is presently stored on computer" I cant get it to pull any codes. Any help would be appreciated! Thank you.
G
check the roll over sensor on the fire wall on the passenger side it will have a button like thing on the top if you want I can send you a picture tomorrow if you like to know what i am taking about. i have seen these go bad before and cause the problem you are explaining
X2 on the rollover sensor. Designed to disable the fuel pump and turn on the hazards. Could be as simple as just re-setting it. Check it out.
1 - 4 of 4 Posts
