1 - 5 of 5 Posts
Discussion Starter · #4 ·
Been using 5w30 Mobil 1 from local Indy or Castrol from dealer. 2nd really good local Indy says motul 5w40 is what they use and they love it. More expensive but better in the south in hot Summer's. Have read that motul is really good stuff
The first number "5W" is the viscosity when the oil is cold. The second number 30 or 40 is the viscosity it acts like when hot. So the higher the second number the better it will operate when the engine runs hotter in hotter climates or working it hard. So go for the first number that the manufacturer specifies and then go for the oil that has the highest second number that still has the required first number. I think the best you will find is 5w40.
1 - 5 of 5 Posts
