1 - 8 of 8 Posts
the bogger life
Discussion Starter #1
need some advise on what i can do to increase horsepower on m 2004 land rover disco with a 4.6.
Administrator
How much power and to do what with? What are you using your truck for?
Reptile Expert
plugs, wires, exhaust, there is also a company that you can send your ECU out to and get it chipped for a good 20 or so HP. you can also get a custom cam done. but in the end you're gonna gain only a couple of horsepower for a couple thousand bucks. an 04 disco isnt made for power, no disco is. you could also add a Cold air intake, but ruin your ability to drive in any wet conditions off-road.
the only reason i could see a want/need for more get up and go is for towing purposes. don't mod your rover's motor unless you have to, it isnt made for speed if that is what you're looking for.
The amount of power is only limited by your wallet. You can supercharge it, stroke it, Head work, change compression ratios, etc, etc.
1 - 8 of 8 Posts
