Got the time to do a little more digging. Turns out Ashcroft sells rebuilt R380s (for an expensive but not horrendous price given used R380 prices here in the US), and I can pay a little bit extra for upgraded bearings and different 5th gear ratios, so I'm happy about that. Will need to find pedal assembly, shifter assembly, and source clutch cylinders, lines, and other odds and ends as well, which might prove to be more of a challenge. Then there's the challenge of getting a bellhousing and making an adapter plate/getting a clutch that will work, but that's pretty far down the road.
As for transfer case, I've decided to get a diff lock unit from a junkyard or eBay wrecker at some point. I will also need a shifter for that at the same time. I will decide whether or not to make it selectable 2WD when I get this transfer case. The old non-locker box is fine, so it will be sold to help fund the project.
Also, my timeframe has been knocked back. The engine machining class I plan on building my Volvo 5 cylinder in is only available to take next fall. This is fine with me, as it gives me time to pull the Volvo engine, research/buy a transmission and related parts, and part out the Volvo donor car over the coming summer. Then I'll figure out getting everything in the car the following summer and getting wiring and stuff figured out.
Not a whole lot to report, but figured I'd update. Will probably be a while until the next update.
