1 - 2 of 2 Posts
Howdy kind folks,
I noticed the check engine and SRS lights on in my 96 Disco, so I stopped by an Autozone place and had the codes pulled. The following are the codes the ObdII scanner gave:
P1193 - ??????
P0158 - O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0441 - Evaporative Emission Control System Incorrect Purge Flow
I got the code meaning from http://www.obdii.com/codes.html
Any ideas as to what these are and what needs to be done to fix them? Please I am not mechanically inclined, so help break it down for this novice.
I just recently did an oil change, tune-up and had the fuel filter changed because the Disco was stalling and took too long to start............ a problem that is still occurring.
Thanks!
· Premium Member
po158 is the O2 sensor passenger side after that catalytic converter.
The purge problem I would suspect you have a vacuum leak in the system..or it is plugged, if you have hold of a fog machine use that or just follow the vacuum lines to see if they leak at all...
P1193 i have no clue.....
1 - 2 of 2 Posts
