Well, for better or worse, I got my oil pan fitted today. I had a heck of a time getting it up clear of the oil lines and the drive shaft but I finally got it. Hopefully it doesn't leak.
Now for the stupid. My oil line that goes up into the the front cover from the bottom was dripping oil right where I needed to work. So, I stuck a small piece of paper towel in it hoping to stop the leak long enough to get the pan fitted. While fitting the pan, I moved this line around quite a bit. When done, I noticed the piece of paper towel either fell out or got pushed down into the line. Since I can't find any evidence of the piece of paper towel on the ground, I'm guessing it got pushed into the line. I took a piece of wire, bent a small hook on the end and went digging for the towel but didn't pick anything up. Question now is, what to do? How stupid could I have been to not see this coming!
I imagine if the piece of paper towel is in the line, it would get pushed up into the front cover and eventually find it's way into the oil cooler and clog things up. Not sure what to do now. Any suggestions?
Thanks
Thanks
