1 - 5 of 5 Posts
92 Rover Classic
What is the setup for the stock center muffler heat shield, to protect the floor?? Are there aftermarket units avaliable?? I recently had a hole in the top of the center muffler, and guess what, the carpet mat (foam or rubber mat) under the rear floor carpet melts,smokes and smells really bad. Is there a solution for this potential "hot problem"?? :beer:
Irvin said:
92 Rover Classic
I've heard of some folks going to Home Depot or Lowe's and purchasing a piece of alluminum (or some metal sheet) and attaching it to the top of the muffler. The original heat shields are over $70 (jeesh).
Why not replace the muffler at a local Midas shop? I have a flowmaster muffler and a straight pipe in the rear section and it's really not that loud.
Good luck,
John C.
Discussion Starter · #4 ·
John C
Good luck,
John C.
THanks for the info. I've had the center muffler replaced, in fact the center muffler was a lifetime warranty stainless unit. I'm worried about future problems and general summer heat plus hot exhaust getting north into passenger compartment. I did more research and found that Atlantic British has a $59 replacement. Thanks!!
Just replaced the same part on my 95' LWB - ordered mine from Atlantic British as well. Good luck - definitely need one, rear carpet will start to burn otherwise
1 - 5 of 5 Posts
