1 - 2 of 2 Posts
Hey everyone,
I'm replacing the exhaust manifold and gaskets on my '97 disco XD. The passenger gasket is completely blown and the manifolds are in bad shape. Anyone have any tips for an easier removal process? I've sprayed down the bolts with some PB blaster to make them a little easier to remove. The lower manifold connection to the Y pipe is a bit rusted so if I have to drill out the studs I will.
Thanks all!
Administrator
We deal with lots of rust and corrosion up in my part of the continent,
Heat with an acetelene torch will likely be most effective
1 - 2 of 2 Posts
