So I live in California, and my 99 Discovery II failed the smog check because the check engine light DOES NOT come on for the "self check" when starting the engine.
The tech said that the EMS is is sending the signal to illuminate the light but it's not coming on.
I have pulled the instrument panel and there mini LEDs soldered to the board and visually everything looks ok.
Is there a relay, fuse, or other connection that I should look for?
Does the instrument cluster need to be replaced?
Other smog issues.
Code. P1590 abs sensor, but how can you tell which sensor?
Code. P0446 evap system vent control malfunction. Where do I start?
Other smog issues.
