1 - 5 of 5 Posts
Hi
The alarm on my 2001 freelander has just started to set it self of after about 15 mins.This only happens when the doors are locked using the remote fob,using the key everything works fine.
Does anyone know of a fix to this problem .
Any help
Thanks Andy
If it's only when using the remote,it points to the ultrasonics,when you lock manually with the key it only arms perimetrically.From memory,a dealer should be able to turn the sensitivity of the sensor down if a fault is not present.
Mick
wondadust said:
Hi
Any help
Thanks Andy
1 - 5 of 5 Posts
