Car is a 2003 Disco SE with 110K miles. Bought it in July 2011 with 77K miles and it's been near rock solid ever since with nothing but fluid changes and minor replacement parts. However I've been collecting parts for a year to do the timing cover rebuild and fix some leaks, and this past weekend I was finally able to get started.
I had no intention of doing the work until I got some free time around the holidays, but last Monday I noticed a pinhole coolant leak coming from the plastic distribution fitting on the lower coolant hose. Wasn't serious so I ordered the part and kept driving. Then on my drive to work Wednesday morning I notice my battery light start blinking and my voltage start to vary wildly, between 11.9-17.1! Turned it around immediately, parked it and planned to start work early Saturday.
I've been dealing with seeping oil pan and timing cover gaskets, and I was pretty sure my front crank seal was gone too, judging by the amount of caked on oil around my timing cover. I figured if I was going to do something I may as well do it right, so I decided to tear all the front end parts off and replace everything - ending with the oil pump gears. I even managed to pull my leaky steering box and rebuild the top plate with new gaskets. I thought it was going to be an absolute bear of a job to get it out, but it only took maybe 30 minutes!
Below are some pictures of the process.
Acessories removed, notice the filthy timing cover for years of leaking:
Closeup:
The culprit:
The parts, cleaned and organized:
Rebuilding the pulleys using high quality Nachi Japanese bearings. #6203 for the smaller pulley and #6304 for the larger pully are in fact the right numbers. Only needed some snap-ring pliers and a bench vise for removal and installation of the bearings - quite easy.
I guess I should consider myself lucky - the oil pump ring gear came out in three pieces. It still managed to keep the pressure high enough because god knows how long i've been driving like this, but maybe this would explain my intermittent lifter noise during startup.
With the cover off I also noticed a lot of slack in the timing gears and chain, so I'll be replacing those too - cheap and easy. I'm also going to take this opportunity to do what I've wanted to for a long time on this car - install an oil pressure gauge and convert the ancient clutch fan design to a modern electric thermostatically controlled fan. It will run cooler, the engine won't have as much rotating mass attached to it, and I'll have lots more room to work under the hood. I'll post a write-up as I go along.
The purpose of this post was to show a bit of my handy work but also prove to some guys that are hesitant about doing their own teardown that it really is a pretty straightforward job - frankly it's one of the easiest "major" jobs I've ever undertaken on any car. The only "specialty" tools you need are the fan clutch removal tool (or use a crescent wrench) and a breaker bar with a 15/16 socket to remove the crank pulley. That's it. Everything came apart easy and the only struggle was removing the damned paper gasket on the water pump which had burned itself to the aluminum sealing surface.
Sorry for the long post and thanks for the read. I'll keep you guys updated as I go along.
Closeup:
The culprit:
