flashing gear lights wont go into gear
1670 Views 4 Replies 2 Participants Last post by  jeffinmadison
I have a 2000 disco 2 the M and s lights were flashing and was sometimes sluggish off the line. Now they are flashing as well as the top left corner the gear light with yellow x through it flashes, and when I put it in gear nothing, then when I put it back in park the shifter kinda vibrates as though its trying to catch. I have no gears at all.
thanks jeff
1 - 5 of 5 Posts
Good on trans. Fluid? To check, there is a side plug on the pan. With it out, you should be to the point of it almost flowing out when full
Mike Russell
Age 18
2003 discovery se
Lover of Rovers
Yes I checked it and it doesn't seem to be burnt either
And your transfer case is in gear? And you transmission cable attached?
Mike Russell
Age 18
2003 discovery se
Lover of Rovers
Ok I will check that and let you know thanks
1 - 5 of 5 Posts
