1 - 3 of 3 Posts
if its the cd version,
use 4 peices of coat hanger or similar to push into the holes around the facia this should release it,
if there are onyl 2 holes then you need to use a small allen key to release it
then pull like hell
Rookie
To remove the stereo system in a ML05 Freelander you have to take the centre console out and the front facia around the stereo unit, the stereo appears to be three separate pieces but actually its all one unit. Its basically the same stereo found in Fords now.
Hope this helps
Regards
Steve
1 - 3 of 3 Posts
