1 - 5 of 5 Posts
I'm getting the chirping from front under car and from what I've seen here, seems it's a drive shaft problem. Atl Brit has OEM with all three greaseable joints for 529$. Does it bolt right in or do I need to do some measuring etc? Also are the existing bolts ok or should I replace them also?
You can rebuild it for under $100.
If you're not comfortable doing that, you can get it rebuilt for $150-$200. Or you can get a heavy duty for around $300.
Google tom woods drive shafts or great basin rovers
Rebuild it with some greaseable ujoints. Just make sure when you take it apart to mark the parts so they go back together the same way. Sometimes if you don't you will accidently make it unbalanced. Seen it happen once. Specifically talking about the joint in the axle...not the ends
1 - 5 of 5 Posts
