1 - 7 of 7 Posts
Discussion Starter #1
Hey guys, I couldn't find this asked before.
My front driveshaft is rubbing on the passenger side cat. How do I make it not do that??
very disco
I would imagine that your exhaust system is displaced rather than your driveshaft.
Super Moderator
There should be plenty of clearance between the shaft and exhaust.
I will assume that at some point in time the exhaust has been modified???? Catalytic converters changed??
Discussion Starter #4
Upon closer inspection I think that's exactly what happened. There's some weld points that look like they replaced the cat. I'm thinking I'll just push the pipe over with a crowbar. Just so long I don't kink or crack it, it should be fine.
very disco
you might also find some relief by swapping/fussing with the exhaust hangers
Super Moderator
Front pipe is pretty much fixed in place, not much if any adjustment
1 - 7 of 7 Posts
