1 - 3 of 3 Posts
Just rolled over 200k miles on the rover and has developed a leak at the front of the motor. I think it's the front main seal. Have holiday time next week and would like to get it taken care of has anyone tackled this? Is pretty straight forward? Looking at the parts catalog photos it looks like its replaceable from the front with out having to take the timing cover off, is that the case? Any other preventative maintenance (other than the water pump) I should do while I'm at it?
member
Good to see that it has run that many miles.
Check that it's not coming from the trans cooler line from the radiator. Mine was loose and it was dripping transmission oil from front of the engine.
Have you had to replace or fix the diffs?
is it a V8 or V6?
Dave
Definitely engine oil. Had to replace the rear diff partly my own fault, it had a leak I let go to long and it went pop. Luckily found one on craigslist only 50miles away and it only took about 2 hours to replace. V8
1 - 3 of 3 Posts
