1 - 6 of 6 Posts
Hi All,
I have a 2005 LR3 with a "single door not locking” issue.
Here are the details:
When I use either the key remote or the upper dashboard door lock button, my front passenger door does not lock along with everything else. The other doors, etc. work fine, allowing me to lock/unlock as needed. However, I can see the front passenger door lock button (the button ON the door) move slightly when the key remote is pressed, or when I press the lock button on the center console (while I’m sitting in the car). So I suspect power is reaching the door. But it does not snap into the lock position like the other doors. The button also has some resistance when I physically push it to lock the door. I am unable to lock it when physically pushing the offending lock button [on the door]. Only on a couple of occasions that door lock has correctly. The vast majority of times it will not, leaving the car unprotected. The alarm works. After setting the alarm, the front passenger door is not locked, so when opened, the alarm will go off. I feel that power is reaching the door lock. But the lock will not latch properly. Anyone have any suggestions as to how I can get this to operate correctly? Thanks in advance.
I had my front windows tinted to match the rear, and suddenly the front passenger door wouldn't open from the inside. This did the trick! Getting the cassette clipped back in took a bit of a finger workout, but that video was a nice help. On to other gremlins!
1 - 6 of 6 Posts
