1 - 3 of 3 Posts
Hey everyone I am running out of ideas. I have a 93 RR. I get a misfire on cylinder #1 when I first start the truck, it clears up after 30 seconds or so. I changed the injectors and spark plugs for good measure, thinking one was leaking, No change. I pulled the spark plug and looking in there with a camera. The cylinder is all wet. Smells like fuel. I have run out of ideas of what could be causing this problem. I also occasionally get either a preignition or a hydro lock scenario when I first start the truck too. Please help!
You changed the injectors. With new, cleaned, etc., or used?
Sounds like you have a leaking injector. Fix it before it scrambles your engine with a real hyrdo-lock.
I changed them with remanufactured injectors. Ford 19LB. injectors. Same cylinder same issue. I thought maybe the intake was leaking too, I checked using brake cleaner, no change in rpm.
1 - 3 of 3 Posts
