1 - 4 of 4 Posts
Discussion Starter #1
Hi all, Just brought a Disco 2 td5. First LR I've owned and love it. first question, fuel pump runs up to pressure when the ignition key is turned to ignition and then stop once fuel pressure to the pump is acheived. this is a correct?
very disco
Welcome to the forum!
i suck at fuel delivery so I’ll leave your question to be answered by the more knowledgeable patrons
Hi, it's not about pressure cos there is no pressure sensor on the Td5's fuel delivery system, there is a timer in the ECU for that, the pump should run 3 minutes with ignition on II then stop if the engine was not cranked... you can find all the info in the WSM, download this Workshop manual.pdf
91772
Drives like an old man
And for the record, you can always take what Sierrafery says as gospel. He is easily the most helpful contributor on this site.
1 - 4 of 4 Posts
