1 - 3 of 3 Posts
My (former) mechanic seems to have fallen in love with the fuse id page from my manual & ran off with it.
Does anyone have that page? A copy would make my life much easier. (I couldn't find an electronic copy on the web anywhere).
Current problem is that the key only operates the driver's door, not all of the other locks - anyone know which fuse that is?
Thanks.
That is not a fuse issue, it is a programming issue with the alarm/lock system. Go have someone scan it for a failure.
Mike J.
A D1's drivers side lock is the "Master" for the entire lock system. It is the only one that unlocks all the doors & disarms the security system. If it is not doing what it should do, then clean contacts and/or replace actuator as needed. Good Luck, LRW
1 - 3 of 3 Posts
