1 - 3 of 3 Posts
Discussion Starter #1
Range Rover Classic 1973,
Could anybody tell me if I can use a Borg-Warner transfer box from a 1994 RR classic 3.9 efi Automatic to a LT85 (santana) 5 speed gear box.
The engine is a standard 3.5 V8. I know it fits but my question is: does the gear ratio fit (the car is for road use only).
Rover-Holic and Admin
It should work fine as I believe the LT230 and the BW case had similar ratios
You might find that you will need to change the prop shafts as well.
You will also have to worry about the different handbrake setups.
1 - 3 of 3 Posts
