1 - 6 of 6 Posts
:eek:
HERES ONE FOR YOU GUYS THEN.
WHEN I INDICATE TO TURN RIGHT A GREEN TRAILER FLASHES ONCE THIS IS NORMAL BUT WHEN I INDICATE LEFT IT KEEPS FLASHING IN CONJUCTION WITH THE INDICATOR,
I HAVE CHECK THE INDICATORS AND THEY SEEM TO BE WORKING FINE,
COULD ANYONE GIVE ME THERE THOUGHTS ON THIS.
MANY THANKS FOR ANY REPLYS
do you have trailer wireing on your rover?
I guess that's 'MOGWAI' off 'Mud-Club'.
See the replies there
zerocool said:
:eek:
Check the trailer socket itself - most likely it's full of damp mud or something and is causing just enough current to pass to make it think there's a trailer attached. Had the same on mine :mad:
A good squirt of WD40 or some other protective stuff is normally enough to restore things back to normal :drive:
The trailer light is SUPPOSED to flash when there's a trailer attached to let you know the bulbs are working :wave:
1 - 6 of 6 Posts
