Yep, that is the sound that comes from the fuel tank area of my '95 RRC LWB. I have been told that it is either the charcoal filter or the check value. While I do have the bible for this model, I am hoping someone could describe the best method for 1) figuring out which item is causing the problem and 2) fixing the damn problem. Symptoms:
When the SexyBeast has less than 1/4 of a tank of fuel, she idles very roughly and has been known to stall. I removed the fuel cap after one such stall and was nearly knocked off my feet by the pressure blasting out of the filler tube. As mentioned above, she also makes a gurgling sound (when I am idling at a stop light or similiar) when the tank is low.
Any wisdon, hopefully the precise kind?
Thanks.
Thanks.
