Ok, to start off I have a 96 Disco 5-speed. I decided I needed to clean out the pcv valve on the valve cover. It was totally clogged. I got that all clean, I have replaced all the pcv hoses as well. I replaced the stepper motor, as I broke the old one when I was cleaning it. After all this she ran perfect for about a week. Then as I was driving it one day, while I was shifting between gears the rpms would rise up to 3000 and hang there. If I came to a complete stop, the rpms would drop down to normal in just a few seconds. The next day, at a cold start the rpm would rise up to 2000 start to fall, then rise back up to 2000+ until the engine is warm. The hanging idle between shifting still persists. I unpluged the speed transducer, the hanging between the shifts went away, but the cold high idle startup remained. I have changed the front O2 sensors before, about 30k ago. PLEASE HELP!!!!!!!!!! I don't know what else it could be!!!
THANKS AHEAD OF TIME!!!!!!!!!
