I've seen similar questions done to death but, maybe my situation/ findings will get someone to chime in with their experience.
My question is my head bolts are currently sitting @72 ft-lbs after the 1st 90° turn.
Am I safe to leave it at that?
All parts were purchased from Atlantic British. My heads weren't warped but I did have to get .007 taken off because the old head gasket wore a crescent gouge into it.
THE BACKSTORY:
I bought a D2 with a blown head gasket and shoddily repaired rust on the frame. Upon teardown I discovered Top hat liners already installed and the apparent cause of the failure were pulled threads in the block.
When reinstalling the head the bolts were slipping at the 15-20 ft-lb mark. Pulled the head back off and installed some Timeserts.
I did the upper and lower holes, put the head back on.. so far so good. 15 ft-lb followed by 90° and the threads to the left let go @58 ft-lb (my torque wrench does angle and tells you the end torque result). Head off... Again, Timeserts.. drilling.. cleaning up metal shavings.. and using my other head gasket since I'm not sure if this one is crushed now.
At this point all the weak threads seem to have been sorted. But after the 15ft-lbs it took 68-82 ft-lbs to achieve a 90° turn. I don't think it would be wise turning these bolts another 90° and I'd appreciate if anyone has seen these these kind of numbers/ results before.
I've also double checked to be sure with a 2nd torque wrench.
Thanks all!
THE BACKSTORY:
Thanks all!
