21 - 28 of 28 Posts
2003 Discovery 2 SE7
Any real reason to do it?
I would assume ease of serviceability - that way the metal tubes aren’t in the way, and the intake doesn’t have to come off to get them out of the way.
very disco
Maybe I’ve had a sheltered life, but SAI has never given me fits or been so in the way that I’ve felt the need to augment it. In fact, it’s kind of a quirky thing that I adore about this damned truck of mine, as long as it’s not grinding heh
  • Like
Reactions: Bigmant773
2002 Land Rover Discovery 2
Discussion Starter · #23 ·
I am actually curious what the hell it actually does. I’ve tried to do a mild amount of research and can’t really figure out what the purpose is, especially because some have it and some don’t haha.
very disco
I believe it’s emissions related. Somebody who knows more than me made a video
Expert Crate Digger
Using flexible hoses instead of the stock SAI metal tube helps with easier removal when troubleshooting coil packs, spark plugs and fuel pressure rail access.
Discussion Starter · #27 ·
Just wanted to close this out! Finished this up yesterday, took me three 6 hour days or so to finish up.
Wow. What a difference. It is like a whole new car for me. I think had 2 of 8 cylinders working as they should. The other 6 all had water intrusion. I was having issues getting the truck up to speed, as in to go 70mph on the highway I had to catch the slipstream off of 18 wheelers just to get down the road. Steep graded hills were almost impossible. I followed the Atlantic British video and it went perfectly.
Highly advise whoever reads this to change out your pushrods and tappets while you’re in there. I had to hammer my old tappets out, so I know they were getting stuck and making some driveline noise. The car is now the smoothest and quietest it’s ever been.
If you are the second+ owner and over 120k on the odometer, these trucks are probably due for a change. Not a hard job, just time consuming.
Of note, if you have secondary air, make sure you have a 9mm Allen head wrench. Either one that goes on a 3/8th drive socket wrench or the L shaped kind. They don’t come in most sets, so you’ll need to get it as a single socket from autozone. You need it to remove and reinstall where the secondary air lines go into the block.
Enjoy!
Expert Crate Digger
Congrats!
21 - 28 of 28 Posts
