1 - 2 of 2 Posts
I got the head studs to put into my Disco and I need to know how to tighten the studs. I know the studs themselves go in hand tight, and you tighten down in the same pattern as the stretch bolts. But do you tighten in steps or just all at once. And finally, what torque do you tighten to in the end? As always, thank you much
I tightened in steps 20-42-64 Don't tighten to bolt specs as it will pull out the studs from the engine block.
So I did mine at 64 foot pounds one year ago and 16,000 miles. All is well.
1 - 2 of 2 Posts
