I have a '07 RRS SC and had the same issue. I replaced the heater core on mine which improved the heat but it isn't fixed. Get a good scan tool for your Range Rover and see if you have faults for the heater Blend doors. I checked that on mine after replacing the Heater core and it showed a door stuck with a potentially bad motor. I would have had some motors repaired or replaced if I'd have known. Kind of a known issue with these...
I use the heated seats often...
