1 - 3 of 3 Posts
So my heats been stuck on low. I replaced the blower motor resistor thinking that was it. Nope so I ripped apart the dash to clean the contacts for the 4 way switch and when I pulled the plug it was all black like it got burned up. Anyone in countered this b4
do ya mean the switch on the heater assembly...
and did you get the new resistor pack...
but no havent had this happen... id get another switch,,,,
you can test you blower if the dash is apart.. you can unplug on the right side
... it is close the the resistor pack plug,,,,, and power it at plug...it will be on high,,,just for the test...
.. sorry this may not apply to you... i just read other post and you have a 95....i think my kind of heater assembly is only up to the 93
yes the heater assembly switch
yes i had gotten a new resistor pack solved nothing.
i was thinking another switch too but i was thinking that might also be a wire problem somewere.
i might have to try that. cuz actually if i could just leave it on high all the time ill be happy too. just sucks only have low
1 - 3 of 3 Posts
