1 - 9 of 9 Posts
Hi everybody,
I have a question regarding a 300tdi classic 1994 softdash.
I bought this quite neglected car a couple of months ago and still find surprises, but that's not stressing me too much.
But... the heater should work in winter I'd say..
The two heater hoses next to the firewall don't get warm, other than that everything seems to be fine, well apart from the missing heat.
Do you have any advices for me? I got an appointment in a local garage mid January, so maybe I can somehow sort it out myself not waiting and freezing for a month.
Cheers,
Fabian.
Do you have a picture of your engine bay and the hoses? Often with rovers when the heater core starts to leak, rather than replace it (becasue it's a nightmare) people will just abandon it by plugging the heater hoses or just looping them back on themselves to bypass the heater core. It's possible the hoses have been intentionally blocked due to a previous heater core leak.
Hi Lance,
That's a good idea. Thank you.
I just went to the car and did some pictures.
On other posts I read that the heater is a bit sensible about the correct amount of cooling liquid. It was aprox a 1cm below max and i filled it up now.
Tomorrow i have to use the car anyway and will find out if theres a difference.
I'm limited in my knowledge of the diesels (the hoses in the V8 are a completely different configuration), but it looks like there is a control valve that allows flow into the heater lines, perhaps similar to BTR4022. If this valve is stuck or frozen, I don't believe any water will make it into the lines, or therefore into the heater core.
1993 Range Rover County Classic SWB
If you are getting 0 heat even after letting motor get up to temp, it's probably the heater core.
Mine was giving a very small amount of heat and it ended p being the thermostat getting stuck too cold. New thermo, now has heat.
1 - 9 of 9 Posts
