1 - 3 of 3 Posts
I am looking to see if this is as simple as using the existing wiring for the Hella's. or do I have to use the new wiring harness. I wil be running the standard bulbs.
You can run the standard wiring. Realize though that the wiring is set to allow aux. lighting like fog lights to be on
only with low beam headlights. There is a relay system built in so the high beams will not run at the same time as the fog lights.
I use the factory wiring and run 3 HID lamps, so go for it.
Mike J.
1 - 3 of 3 Posts
