1 - 5 of 5 Posts
So i have a 2004 land rover discovery 2 with 87000 miles on it
it had the head gasket done at 67000 the car is amazing and i love it but,
the amount of check engine code that popped up almost blow my mind
I REALLY NEED HELP im a college student and i and in need of inspection
the 2 amigos is on but i will take care of that this weekend
p1000(86)
p0413
p1482
P0444
P0447
P1457
P0102
P1591
P1000(10)
P0154
P0135
P0155
P0140
P0257
P1000(14)
P1000(4)
P1000(75)
P1000(62)
P0159
First of all erase those codes then go for a ride and read again cos it's possible that most of them to be hystorical
Yeah- you've got yourself a mess there. Go buy a decent scan tool. I would start by indexing all the codes you have, then reset the ECU and see which one's come back and index them in order. You'll have to start lumping them together and begin tackling each of them. Once you' get organized, come back and maybe some members can help you with which one's are related to the same problem or are being caused by something else.
To get you started, below is a list of codes. You need to download the Rover factory manual, called RAVE. it's tough to navigate, but find your way to the Discovery 2 section and dig in.
P0101 - Air flow to throttle angle cross check fault Drive cycle B:Signal implausible.
P0102 - Mass air flow sensor fault Drive cycle A:Signal out of range - below minimum.
P0103 - Mass air flow sensor fault Drive cycle A:Signal out of range - above maximum.
P0112 - Intake-air temperature sensor fault (in MAFS) Drive cycle B:Signal out of range - below minimum.
P0113 - Intake-air temperature sensor fault (in MAFS) Drive cycle B:Signal out of range - above maximum.
P0116 - Engine coolant temperature sensor input fault Drive cycle D:Signal implausible.
P0117 - Engine coolant temperature sensor input fault Drive cycle D:Signal out of range - below minimum.
P0118 - Engine coolant temperature sensor input fault Drive cycle D:Signal out of range - above maximum.
P0122 - Plausibility check - throttle angle Drive cycle B:Signal out of range - below minimum.
P0123 - Plausibility check - throttle angle Drive cycle B:Signal out of range - above maximum.
P0130 - Lambda sensor upstream catalyst bank 1 Drive cycle C:Signal implausible.
P0132 - Lambda sensor upstream catalyst bank 1 Drive cycle C:Signal out of range - above maximum.
P0133 - Lambda sensor aging tp bank 1 Drive cycle C:Signal out of range - above maximum.
P0133 - Lambda sensor aging tp bank 1 Drive cycle C:Signal out of range - below minimum.
P0134 - Lambda sensor upstream catalyst bank 1 Drive cycle C:Signal missing.
P0135 - Oxy Sensor Heater Upstream Cat bank 1 Drive cycle C:Signal out of range - above maximum.
P0135 - Oxy Sensor Heater Upstream Cat bank 1 Drive cycle C:Signal out of range - below minimum.
P0136 - Lambda sensor downstream catalyst bank 1 Drive cycle C:Signal implausible.
P0137 - Lambda sensor downstream catalyst bank 1 Drive cycle C:Signal out of range - below minimum.
P0138 - Lambda sensor downstream catalyst bank 1 Drive cycle C:Signal out of range - above maximum.
P0139 - Lambda sensor aging downstream bank 1 Drive cycle C:Signal out of range - above maximum.
P0139 - Lambda sensor aging downstream bank 1 Drive cycle C:Signal out of range - below minimum.
P0140 - Lambda sensor downstream catalyst bank 1 Drive cycle C:Signal missing.
P0141 - Oxy Sensor Heater Downstream Cat bank 1 Drive cycle C:Signal out of range - above maximum.
P0141 - Oxy Sensor Heater Downstream Cat bank 1 Drive cycle C:Signal out of range - below minimum.
P0150 - Lambda sensor upstream catalyst bank 2 Drive cycle C:Signal implausible.
P0152 - Lambda sensor upstream catalyst bank 2 Drive cycle C:Signal out of range - above maximum.
P0153 - Lambda sensor aging tp bank 2 Drive cycle C:Signal out of range - above maximum.
P0153 - Lambda sensor aging tp bank 2 Drive cycle C:Signal out of range - below minimum.
P0154 - Lambda sensor upstream catalyst bank 2 Drive cycle C:Signal missing.
P0155 - Oxy Sensor Heater Upstream Cat bank 2 Drive cycle C:Signal out of range - above maximum.
P0155 - Oxy Sensor Heater Upstream Cat bank 2 Drive cycle C:Signal out of range - below minimum.
P0156 - Lambda sensor downstream catalyst bank 2 Drive cycle C:Signal implausible.
P0157 - Lambda sensor downstream catalyst bank 2 Drive cycle C:Signal out of range - below minimum.
P0158 - Lambda sensor downstream catalyst bank 2 Drive cycle C:Signal out of range - above maximum.
P0159 - Lambda sensor aging downstream bank 2 Drive cycle C:Signal out of range - above maximum.
P0159 - Lambda sensor aging downstream bank 2 Drive cycle C:Signal out of range - below minimum.
P0160 - Lambda sensor downstream catalyst bank 2 Drive cycle C:Signal missing.
P0161 - Oxy Sensor Heater Downstream Cat bank 2 Drive cycle C:Signal out of range - above maximum.
P0161 - Oxy Sensor Heater Downstream Cat bank 2 Drive cycle C:Signal out of range - below minimum.
P0171 - Additive adaptive mixture correction TRA bank 1 Drive cycle B:Signal out of range - above maximum.
P0171 - Mixture adaption factor FRA bank 1 Drive cycle C:Signal out of range - above maximum.
P0172 - Additive adaptive mixture correction TRA bank 1 Drive cycle B:Signal out of range - below minimum.
P0172 - Mixture adaption factor FRA bank 1 Drive cycle C:Signal out of range - below minimum.
P0174 - Additive adaptive mixture correction TRA bank 2 Drive cycle B:Signal out of range - above maximum.
P0174 - Mixture adaption factor FRA bank 2 Drive cycle C:Signal out of range - above maximum.
P0175 - Additive adaptive mixture correction TRA bank 2 Drive cycle B:Signal out of range - below minimum.
P0175 - Mixture adaption factor FRA bank 2 Drive cycle C:Signal out of range - below minimum.
P0201 - Fuel Injector fault - cylinder 1 Drive cycle A:Signal missing.
P0202 - Fuel Injector fault - cylinder 2 Drive cycle A:Signal missing.
P0203 - Fuel Injector fault - cylinder 3 Drive cycle A:Signal missing.
P0204 - Fuel Injector fault - cylinder 4 Drive cycle A:Signal missing.
P0205 - Fuel Injector fault - cylinder 5 Drive cycle A:Signal missing.
P0206 - Fuel Injector fault - cylinder 6 Drive cycle A:Signal missing.
P0207 - Fuel Injector fault - cylinder 7 Drive cycle A:Signal missing.
P0208 - Fuel Injector fault - cylinder 8 Drive cycle A:Signal missing.
P0261 - Fuel Injector fault - cylinder 1 Drive cycle A:Signal out of range - below minimum.
P0262 - Fuel Injector fault - cylinder 1 Drive cycle A:Signal out of range - above maximum.
P0264 - Fuel Injector fault - cylinder 2 Drive cycle A:Signal out of range - below minimum.
P0265 - Fuel Injector fault - cylinder 2 Drive cycle A:Signal out of range - above maximum.
P0267 - Fuel Injector fault - cylinder 3 Drive cycle A:Signal out of range - below minimum.
P0268 - Fuel Injector fault - cylinder 3 Drive cycle A:Signal out of range - above maximum.
P0270 - Fuel Injector fault - cylinder 4 Drive cycle A:Signal out of range - below minimum.
P0271 - Fuel Injector fault - cylinder 4 Drive cycle A:Signal out of range - above maximum.
P0273 - Fuel Injector fault - cylinder 5 Drive cycle A:Signal out of range - below minimum.
P0274 - Fuel Injector fault - cylinder 5 Drive cycle A:Signal out of range - above maximum.
P0276 - Fuel Injector fault - cylinder 6 Drive cycle A:Signal out of range - below minimum.
P0277 - Fuel Injector fault - cylinder 6 Drive cycle A:Signal out of range - above maximum.
P0279 - Fuel Injector fault - cylinder 7 Drive cycle A:Signal out of range - below minimum.
P0280 - Fuel Injector fault - cylinder 7 Drive cycle A:Signal out of range - above maximum.
P0282 - Fuel Injector fault - cylinder 8 Drive cycle A:Signal out of range - below minimum.
P0283 - Fuel Injector fault - cylinder 8 Drive cycle A:Signal out of range - above maximum.
P0300 - Emission relevant misfire multiple cylinders Drive cycle C:Signal out of range - above maximum.
P0301 - Catalyst damaging misfire cyl 1 Drive cycle C:Signal out of range - above maximum.
P0301 - Emission relevant misfire cyl 1 Drive cycle C:Signal out of range - above maximum.
P0302 - Catalyst damaging misfire cyl 2 Drive cycle C:Signal out of range - above maximum.
P0302 - Emission relevant misfire cyl 2 Drive cycle C:Signal out of range - above maximum.
P0303 - Catalyst damaging misfire cyl 3 Drive cycle C:Signal out of range - above maximum.
P0303 - Emission relevant misfire cyl 3 Drive cycle C:Signal out of range - above maximum.
P0304 - Catalyst damaging misfire cyl 4 Drive cycle C:Signal out of range - above maximum.
P0304 - Emission relevant misfire cyl 4 Drive cycle C:Signal out of range - above maximum.
P0305 - Catalyst damaging misfire cyl 5 Drive cycle C:Signal out of range - above maximum.
P0305 - Emission relevant misfire cyl 5 Drive cycle C:Signal out of range - above maximum.
P0306 - Catalyst damaging misfire cyl 6 Drive cycle C:Signal out of range - above maximum.
P0306 - Emission relevant misfire cyl 6 Drive cycle C:Signal out of range - above maximum.
P0307 - Catalyst damaging misfire cyl 7 Drive cycle C:Signal out of range - above maximum.
P0307 - Emission relevant misfire cyl 7 Drive cycle C:Signal out of range - above maximum.
P0308 - Catalyst damaging misfire cyl 8 Drive cycle C:Signal out of range - above maximum.
P0308 - Emission relevant misfire cyl 8 Drive cycle C:Signal out of range - above maximum.
P0327 - Knock sensor fault bank 1 Drive cycle B:Signal out of range - below minimum.
P0328 - Knock sensor fault bank 1 Drive cycle B:Signal out of range - above maximum.
P0332 - Knock sensor fault bank 2 Drive cycle B:Signal out of range - below minimum.
P0333 - Knock sensor fault bank 2 Drive cycle B:Signal out of range - above maximum.
P0335 - Reference mark detector fault (Reluctor wheel) Drive cycle A:Signal implausible.
P0336 - Crank sensor tooth fault (flywheel teeth) Drive cycle A:Signal implausible.
P0340 - Camshaft sensor fault/Valve timing error Drive cycle A:Signal implausible.
P0412 - Secondary air valve power stage fault Drive cycle D:Signal out of range - above maximum.
P0413 - Secondary air valve power stage fault Drive cycle D:Signal missing.
P0414 - Secondary air valve power stage fault Drive cycle D:Signal out of range - below minimum.
P0418 - Secondary air pump power stage (relay) fault Drive cycle D:Signal missing.
P0418 - Secondary air pump power stage (relay) fault Drive cycle D:Signal out of range - above maximum.
P0418 - Secondary air pump power stage (relay) fault Drive cycle D:Signal out of range - below minimum.
P0420 - Catalyst deteriorated bank 1 Drive cycle C:Signal out of range - below minimum.
P0430 - Catalyst deteriorated bank 2 Drive cycle C:Signal out of range - below minimum.
P0440 - Evaporative control system fault Drive cycle C:Signal out of range - above maximum.
P0441 - Evaporative control system fault Drive cycle C:Signal out of range - below minimum.
P0442 - Evaporative control system - small leak detected Drive cycle: Forced Leak Test:Signal out of range - below minimum.
P0443 - Canister purge valve fault (power stage) Drive cycle C:Signal out of range - above maximum.
P0444 - Canister purge valve fault (power stage) Drive cycle C:Signal missing.
P0445 - Canister purge valve fault (power stage) Drive cycle C:Signal out of range - below minimum.
P0446 - Purge canister vent valve functionality fault Drive cycle C:Signal out of range - below minimum.
P0447 - Purge canister vent valve/DMTL power stage fault Drive cycle C:Signal missing.
P0448 - Purge canister vent valve/DMTL power stage fault Drive cycle C:Signal out of range - below minimum.
P0449 - Purge canister vent valve/DMTL power stage fault Drive cycle C:Signal out of range - above maximum.
P0451 - Fuel tank pressure sensor fault Drive cycle C:Signal implausible.
P0452 - Fuel tank pressure sensor fault Drive cycle C:Signal out of range - below minimum.
P0453 - Fuel tank pressure sensor fault Drive cycle C:Signal out of range - above maximum.
P0455 - Evaporative control system - large leak detected Drive cycle: Forced Leak Test:Signal out of range - below minimum.
P0500 - Vehicle speed sensor signal error Drive cycle B:Signal missing.
P0501 - Vehicle speed sensor signal error Drive cycle B:Signal implausible.
P0505 - Blocked Idle Air Control Valve Drive cycle A:Signal out of range - above maximum.
P0505 - Blocked Idle Air Control Valve Drive cycle A:Signal out of range - below minimum.
P0560 - Battery voltage not plausible Drive cycle A:Signal missing.
P0562 - Battery voltage not plausible Drive cycle A:Signal out of range - below minimum.
P0563 - Battery voltage not plausible Drive cycle A:Signal out of range - above maximum.
P0600 - CAN Interface timeout Transmission Control Module Drive cycle A:Signal missing.
P0601 - Control unit defective (ROM) Drive cycle A:Signal implausible.
P0603 - Control unit defective (xRAM) Drive cycle A:Signal implausible.
P0603 - Values in fault memory not plausible Drive cycle A:Signal implausible.
P0604 - Control unit defective (iRAM) Drive cycle A:Signal implausible.
P0606 - Knock control self test pulse fault Drive cycle A:Signal out of range - below minimum.
P0606 - Knock control self test zero pulse fault Drive cycle A:Signal implausible.
P0650 - Malfunction Indicator Lamp (MIL) fault Drive cycle A:Signal out of range - above maximum.
P0654 - Engine Speed signal (power stage) Drive cycle A:Signal out of range - below minimum.
P0703 - Solenoid valve lockup clutch check (S/C to +12V).
P0705 - Position switch monitoring.
P0721 - Downshift safety monitoring.
P0722 - Stall speed monitoring.
P0731 - Gear ratio monitoring (1st gear).
P0733 - Gear ratio monitoring (3rd gear).
P0734 - Gear ratio monitoring (4th gear).
P0741 - Lock-up clutch monitoring.
P0743 - Solenoid valve lockup clutch monitoring (S/C to Ground or O/C).
P0748 - Pressure regulator check (S/C to +12V).
P0748 LT - Pressure regulator monitoring (S/C to Ground or O/C).
P0753 - Solenoid valve 1 check (S/C to +12V).
P0753 - Solenoid valve 1 monitoring (S/C to Ground or O/C).
P0758 - Solenoid valve 2 check (S/C to +12V).
P0758 - Solenoid valve 2 monitoring (S/C to Ground or O/C).
P1129 - Upstream oxygen sensors connected incorrectly (swapped) Drive cycle C:Signal implausible.
P1170 - Lambda sensor aging tv bank 1 Drive cycle C:Signal out of range - above maximum.
P1170 - Lambda sensor aging tv bank 1 Drive cycle C:Signal out of range - below minimum.
P1173 - Lambda sensor aging tv bank 2 Drive cycle C:Signal out of range - above maximum.
P1173 - Lambda sensor aging tv bank 2 Drive cycle C:Signal out of range - below minimum.
P1230 - Fuel pump relay fault Drive cycle A:Signal missing.
P1231 - Fuel pump relay fault Drive cycle A:Signal out of range - below minimum.
P1232 - Fuel pump relay fault Drive cycle A:Signal out of range - above maximum.
P1319 - Misfire with Low/Empty Fuel Drive cycle C:Signal out of range - above maximum.
P1412 - Secondary air system fault bank 1 Drive cycle D:Signal implausible.
P1413 - Secondary air system fault bank 1 Drive cycle D:Signal out of range - above maximum.
P1414 - Secondary air system fault bank 1 Drive cycle D:Signal out of range - below minimum.
P1510 - Idle Air Control Valve fault (opening) Drive cycle A:Signal missing.
P1513 - Idle Air Control Valve fault (opening) Drive cycle A:Signal out of range - below minimum.
P1514 - Idle Air Control Valve fault (opening) Drive cycle A:Signal out of range - above maximum.
P1535 - ## Compressor request plausibility fault Drive cycle A:Signal implausible.
P1551 - Idle Air Control Valve fault (closing) Drive cycle A:Signal missing.
P1552 - Idle Air Control Valve fault (closing) Drive cycle A:Signal out of range - below minimum.
P1553 - Idle Air Control Valve fault (closing) Drive cycle A:Signal out of range - above maximum.
P1562 - Battery supply check.
P1590 - Rough road signal implausible Drive cycle A:Signal implausible.
P1591 - Rough road signal implausible Drive cycle A:Signal out of range - below minimum.
P1592 - Rough road signal implausible Drive cycle A:Signal out of range - above maximum.
P1601 - EEPROM Fault (Checksum fault).
P1606 - EEPROM Fault (Communication fault).
P1606 - Watch dog check.
P1612 - Highside switch control cannot switch on or has S/C to ground.
P1613 - Highside switch control cannot switch off or has S/C to +12V.
P1663 - Throttle angle / Torque signal (power stage) Drive cycle A:Signal missing.
P1664 - Throttle angle / Torque signal (power stage) Drive cycle A:Signal out of range - below minimum.
P1665 - Throttle angle / Torque signal (power stage) Drive cycle A:Signal out of range - above maximum.
P1666 - Anti-Theft Alarm serial link fault Drive cycle A:Signal implausible.
P1667 - Anti-Theft Alarm serial link fault Drive cycle A:Signal out of range - below minimum.
P1668 - Anti-Theft Alarm serial link fault Drive cycle A:Signal out of range - above maximum.
P1672 - Immobiliser - incorrect code Drive cycle A:Signal implausible.
P1673 - Immobiliser - incorrect code Drive cycle A:Signal out of range - below minimum.
P1674 - Immobiliser - incorrect code Drive cycle A:Signal out of range - above maximum.
P1700 - Low Range signal implausible Drive cycle C:Signal implausible.
P1705 - High/Low range sensing.
P1776 - Transmission torque signal problem Drive cycle B:Signal implausible.
P1810 - MES1.
P1810 - MES2.
P1841 - CAN bus monitoring.
P1842 - CAN level monitoring.
P1843 - CAN timeout monitoring.
P1884 - CAN Message MD_IND invalid (FFh).
P1884 - CAN Message MD_IND invalid (flag F_TL_MES).
P1884 - CAN message MD_REIB invalid (FFh).
P1884 - CAN Message N_MOT invalid (flag F_N_MOT).
P1884 - CAN message T_MOT (Engine temp) invalid (FFh).
P1884 - CAN message V3 (road speed) invalid (FFh).
P1884 - CAN message WFPDK (DKI) invalid (FFh).
At a quick glance, it may just be a tank purge issue and an SAI fault. Those could help contribute to the o2 codes.
I don't know what state you are in, but in Ohio, we have a system called eCheck. The minimums to pass based on direct exhaust readings are a million miles down from what will set a SES light. It's an auto fail with the light on. If you get the truck well warmed up (hot as you can- like hauling ass on the highway) and take it in, reset the light before you hit the lane and they'll sniff it. It will most likely pass. You can get a code read/reset tool at any parts store or WalMart for under $30. It probably won't go very far in helping you with a complicated diagnosis, but it will get you started. The parts store that reads your codes won't reset the light or clear codes.
If you do, you still need to fix the problems. They could be nothing, or it could be a problem that leads to a worse one and a very expensive repair- like ramen noodles for the rest of your life expensive (reference for college kid)
1 - 5 of 5 Posts
