1 - 2 of 2 Posts
I have an 06 LR3 HSE. I had an overheating issue so shop replaced cooling system radiator water pump all hoses etc..
well saw a leak (water on the ground) took it back and now Im being told there may be a crack in the block. My question is where would I buy another so i can have it replaced? Do I buy new or rebuilt etc.. Just payed it off and BAM! Need a new engine...sigh.. Also would it be worth fixing..I love the LR3 would it be like a new car?
Thanks in advance for any and all advice
wow, that everyone's nightmare when a car overheats. more often the head gasket gives out before the block.
Don't rush to do anything. Maybe the shop didn't install clamp tight enough.
Just a little water on the ground keep driving it and keep checking the fluid level.
If it keeps leaking go SOMEWHERE else and get a second opinion both on the job that was done and the possible cracked block.
More info better decision.
1 - 2 of 2 Posts
