I've never heard of the tranny fluid you mentioned. I've only heard of people using ZF Lifeguard tranny fluid, the stuff made by the maker of the tranny.
The diff fluids are correct.
You'll need a new tranny pan if you're wanting to do it right and change the filter. The tranny filter is built into the plastic pan so the whole thing gets replaced. The engine has to be removed from one of the mounts and lifted slightly in order to get the tranny pan off and the new one back on. Just make sure your mechanic knows what he/she is doing.
Colin
Colin
