:shifty: hi all i bought a 1988 range rover 3.5 efi 3 months ago and have had sterling service from her covering many miles without a problem until two days ago, when she turned over and over without starting (not even a cough) left her a bit and tried again to no avail! checked for spark, ok! theres plenty of fuel in tank, fuel pump fuse ok and supply of power from fuse local garage says pump needs replacing after auto electrician checked her out (he pulled of feed to top of plenium chamber? i turned her over no fuel appeared?) so costed it with them £110 for pump £200 for dropping tank and fitting + refitting tank as there is no inspection hatch in floor of load space! + another £150 for fuel tank as mines a little weepie so decided to leave them out, buy parts elswhere cheaper! and do myself! however just tried her again started first time ran for ages rang mechanics who said still needed work as fault in pump could be intermittent! have checked everywhere i can see for bad earth but am no expert would appreciate any advice from you all as im not one for trusting of such quick judgments! thanks in advance a worried range rover lover in dorset england
