Hi,
I'm looking for ideas and or/ solutions for my 2002 DiscoII whose headliner has a couple of spots of sagging.
At this time, it's not bothersome enough for me to tear out the entire headliner and replace it. I understand that eventually the whole thing will probably droop and I'll need to replace it. What I'm looking for is a quick fix and I've read about the following:
1) Hypodermic needle filled with glue, to inject and smooth down
2) Using heat to help reattach the headliner to the factory glue. For this, I'd use a Zippo Hand Warmer and smooth it over the surface. These Zippo Hand Warmers get extremely warm!!
Do you think that either method might be a short term solution?
Any kind of ideas of suggestions would be greatly appreciated. I live in the greater Los Angeles area, so does anyone know of solid automobile upholstery shop? I'll eventually need one. I'm guessing that this kind of job would run about $500.00 out the door, or am I mistaken?
Thanks again for your opinions and feelings on the subject!
LandyII
LandyII
