Thank you in advance for shedding any light towards my way.
Scenario:
2004 Landrover Discovery 2 HSE
Project-Coolant Flush
Yesterday I flushed the system. After hours of googling info/ youtube videos and reading the RAV I am stumped.
So the specs in manual and RAV say the coolant refill
⇒ Refill 24.2 pt
⇒ Fill from dry 26.2 pt
RAV manual instructions:
Fast forward to step 8 (refill)
8. Remove expansion tank from its mounting
bracket. Slowly fill the expansion tank with
coolant, approx. 4 litres (7 pt).
9. Raise the expansion tank approx. 20 cm (8 in)
vertically, coolant will drain into the system.
10. Refill the coolant expansion tank until a steady
flow of coolant is emitted from the bleed hole.
So I have completed what is described. What about the remaining 17.2pts? After pouring 1 gal with overfill tank elevated coolant is already flush with bleed hole. Im trying to add more coolant to reach the 24.2 target as stated with refill specs. Scratching my head here in confusion
Scenario:
⇒ Refill 24.2 pt
