1 - 3 of 3 Posts
Hello,
I own a 2005 Land Rover Lr3 with some kind of electric issue with the auto lighting? My headlights work when I turn the headlight switch to the regular setting. When I turn the switch to the auto position, my headlights will not go on along with my taillights. I changed some fuses awhile back and both worked normally in the auto position. I was driving home one day only to find that the problem was happening again in auto. Any ideas would help please!
I’m having a similar issue. However in the auto setting my dash lights do not work but the headlights do work. Could this be a light sensor? I was reading a much older post. Maybe it’s the actual switch malfunctioning?
very disco
I’m not sure how the logic works on the switch, but it should be relatively easy to rule out with a DMM and electrical diagram
1 - 3 of 3 Posts
