rov'n said:i installed a new radio and i can hear my ignition through the speakers!!!
definitely bad groundHank said:It's just a bad ground...You can install one of those filters, but it will reallt rob you of power in the radio. Thus, you can't crank it up very loud, or not nearly as loud as it could be.
MuddyDisco23 said:definitely bad ground
Check your electrical connections,rov'n said:well not to rain on your parade...but i checked the ground and even relocated didnt help, installed 2 filters one for the front amplification system and one for the rear amplification system and no more noise!
stereo rocks the house!
Adam in NYC USA said:Check your electrical connections,
make sure your battery is up to snuff with the new electrical toys,
is your stock alternator up to the task? You will need to charge your battery and play your amps at the same time when you are driving.
and try to snuff that noise at the source rather than at the amplifiers. You do have EMI supression wires on your ignition system right? (Yeh, right, grin).
BTW, flexible tin-covered copper straps to the hood and chassis grounds do a lot to suppress radiated Electromagnetic Interference.
Adam in NYC.
What was the voltage drop across the battery when you engage the wiring harness? BTW, when that capacitor discharges, it has to get that electrical energy from somewhere, like the battery and the alternator.rov'n said:all of the connections are made via wiring harness, didnt have to splice into anything. load on the alternator is just fine, running a capacitor to the sub amplifier in back.
Again.....It's a bad ground in your system somewhere. Does not have to be at the radio - it could be anywhere. Amp, battery, engine, etc...rov'n said:well not to rain on your parade...but i checked the ground and even relocated didnt help, installed 2 filters one for the front amplification system and one for the rear amplification system and no more noise!
Adam in NYC USA said:What was the voltage drop across the battery when you engage the wiring harness? BTW, when that capacitor discharges, it has to get that electrical energy from somewhere, like the battery and the alternator.
You might want to see if your new gadgets are not causing excessive voltage drop, which can cause additional ignition noise on the power rail. Not to mention that you will drawing additional power from charging system, causing them to work harder and heat up more.
Measure your voltage.
Start the car.
Let the idle do its thing and kick down.
Play something loud and continous without using any of the headlighting.
Turn on all your gadgets including your lighting.
Nothing looks dim or sounds distorted? Then you did a good job. If it does the same in the dead of winter, you did a great job.
Adam in NYC:clap:
