1 - 3 of 3 Posts
01 Disco 240k miles - what are the tolerances like on these engines after this amount of mileage? Seems like I need a new RMS about every 40k...could the crank be walking and causing the seal to go bad?
I am on my second seal in about 40k...trying to decide if I need a new long block or not?
Any suggestions?
Thanks
If you have not replaced your cam and lifters along with a new oil pump kit and timing chain set you are running a weak engine.
As for a new long block, you can't tell till you pull the top and bottom of the engine and inspect it.
1 - 3 of 3 Posts
