1 - 20 of 26 Posts
2003 Discovery 2 SE7
Discussion Starter #1
Took my D2 up on the highway for the first time yesterday. I noticed two things:
  • It drives remarkably well at highway speeds - far better than I expected, and
  • It runs much hotter than I expected.
I have a 180-degree thermostat in it, and despite this, I saw a peak of 206 degrees on the readout (OBDII Bluetooth adapter + the Torque app on my phone), with average temp somewhere around 201-202.
Ambient outside temperature was 90 degrees, the A/C was on full, and it was a hilly stretch (rolling hills, not mountains or anything that steep or long). 65-75 MPH, 2,000-2,500 RPM, never came out of 4th gear in Drive, not aggressive driving at all.
It only came back to under 200 after a 3/4-mile-long downhill with me staying off the gas. On consistent flat level ground, it runs at 198-200 at these speeds.
Usually driving around at lower speeds on back roads and around town (30-45 MPH) it runs at 188-194 degrees.
I replaced all of the coolant hoses when I replaced the thermostat (except heater hoses), replaced the coolant, and bled the system as per the RAVE, so I highly doubt there are air bubbles in the system or anything like that.
It is also worth noting that my truck is lighter than stock because I removed all of the rear seats. It was just me driving - no passengers or cargo.
Knowing full well that these engines can have many heat-related problems, this concern me a little bit, especially since I want to use the truck to tow and haul things in the future, which would only make everything hotter. Are these kind of temps normal? If not, why are they so high, and how should I go about fixing it?
Thanks in advance.
What 180 Thermostat,if it is a whitish Motorad then that is normal, they not seem to really be 180's. I run a Black 78c from Bearmach in my 04 and fully loaded for 3 day off road and a roof top tent I never break 188.6 on the flats at 50-65 and about 195 -197 max on very long steep uphills. I drop to as low as 175 on long coasting down hills. I turned the air on, as a test, there was no appreciable difference but it is not very warm here currently
I found the gray 180 soft spring to be more stable but I ran higher temps at idle.
Discussion Starter #3
It is the black Bearmach 78C. I have had it in there for about a month, and it operates at a consistent 188.6-190.4 when the ambient temps are around 70 degrees. In those kind of temperatures, I have seen as low as 177 on downhills, with the hottest being 197 when going up a steep hill (at around 45 MPH, around half throttle, 3,000 RPM). This is the same setup - completely unloaded, no rear seats, etc. Idle temp never exceeds 195.8, even with AC and the hot ambient temps we have been experiencing here recently - in cooler temperatures, it never breaks 194. I guess it just doesn't really like the high outside temperatures combined with the high engine load at comparably low RPM when driving on the highway. Thanks for the help.
Drives like an old man
Those numbers sound about right. I don't think you have a problem. The temperature rating on the thermostat only determines at what temperature it begins to open, not the final temp. You're right in the sweet spot.
A lot of forum members freak out at anything >200F, but the aux fan doesn't even come on until 212, I recall.
2002 Land Rover Discovery 2
206 may seem a little bit high, but considering it was 90 degrees outside... sounds fine.
As for that thermostat, have look at my recent post about the issue I had with the MotoRad thermostat: Project: Engine Cooling System Replacement
very disco
If you’re getting consistent, reproducible temps... then I’d be content. Expect higher operating temps when the ambient air is warmer.
like it has been said many times, the thermostat doesn’t control your engine coolant temp, it only controls WHEN your cooling system starts flowing through the engine.
Discussion Starter #8
Thanks for the help everyone. Sounds like I should be fine - the temps are consistent and repeatable, and I took it out again today on the same stretch of highway and only hit a max of 203 - it was around 80F outside today.
Good to know. Does the aux fan also occasionally come on with the AC? I had the truck idling for a while in a parking lot with the AC on, and it came on even when the coolant temp was only at 195. I brought the revs up a little (like 1300) for around 20 seconds to get the mechanical fan and water pump spinning faster - that dropped the temp down to 190, but the aux fan kept going. It shut off sometime after I started driving again.
The electric fan is not only for aircon, it's second purpose is to protect the engine when it gets too hot and as LR considers it's too hot only at 212 and swithces it of ar 202 i'd say that when it's hot outside you are OK, also the original thermostat was supposed to be fully opened only at 204 so IMO those who are stressed by temps around 200 are exagerating ... though it's possible that the viscous fan to not lock well if it's old then it will not pull air well, try to stop the blades with a rolled up newspaper when the radiator is hot and if you can you need a new one
  • Like
Reactions: V50_M66
Discussion Starter #10
Interesting. Thanks for the info. I will be sure to test my viscous fan the way you describe and will replace if necessary. Thanks again.
And just for the record, you can take any advice from Sierrafery as absolute gospel. He knows of what he speaks, as has been proven dozens of times.
  • Like
Reactions: V50_M66
Discussion Starter #13
That's what I figured. I have never seen anyone with so much clear, in-depth knowledge of a subject, complete with visual aids and clear explanations. I have found his replies to be immensely helpful.
Very helpful for when I finally visit our trusted aircon servicing shop!
Discussion Starter #17
... seriously though, 205 is fine.
230 is not fine.
Coolant temp land is fun, isn't it?
That's kind of what I figured based on experience with other cars. I'm probably just a little too cautious with it because I really don't want to have to deal with blown head gaskets like so many others have experienced in the past. I recently drove the truck up a long, winding mountain pass, and even at 60 degrees outside, and my cautious driving (~25 mph, revs at 2500 in 1st only, keeping load on the motor low), it still managed to creep up to 217 after a particularly steep section. It came back to 205 quite quickly after taking a break, popping the hood and holding high idle for a minute or so (hitting 212 to turn the electric fan on does help quite a bit to keep it from getting any higher). Didn't hit more than 210 for the rest of the climb. That was a few weeks ago, and I have been watching the coolant level like a hawk, and nothing has changed as of yet. So I'm probably just being overly cautious. It hasn't gotten hotter than 203 on the highway after posting this originally, so that's a good sign.
On a somewhat related note, the cooling systems on these things are quite undersized in my opinion. That was probably 10 minutes of 10-15% grade (with one steeper section), carrying two passengers and some bags, on a 60 degree day. I don't even want to know what would happen pulling large grades in Colorado while towing 5,000 lbs at highway speeds in the heat of summer.
Discussion Starter #19
Radiator looks alright, but I'm not sure how old it is (Calsonic brand, looks decent on the outside - probably not original). I put fresh coolant in it 2-3 months ago when I switched to a 180-degree t-stat. Replaced all of the coolant hoses while I was at it as well. I also tested the viscous coupling fan the way described above and it is fine.
@V50_M66 Here is a some feedback from a short trip I took
Black Td5 Thermostat, Hayden HD, Dorman Fan
82 -85 F outside temp
No heat or air running
30 to 55 Mph on the flats 188 -190
60 and above 194
Long idles in park 194 airing up my tires, sometimes 197 in drive after a while at long lights
Long steep climbs off road at low speed, 1st and second gear low range CDL engaged 206 - 208 max speedo not registering too slow
Long steep climbs off road at low speed, 1st and second gear high range 210- 212 max 5 -10 mph
After those climbs if there is a long downhill temp drops to 183- 177 inside of 2 minutes
If there is a long flat 185-188 after about 3-5 minutes at about 20-30 mph
Inline is going in in the next few days - but temps are as expected other than the 210-212 should dropped the CDL in it was a ugly uphill lots of bouncing and traction control. Also right after I had idled for 10 minutes or so airing up.
1 - 20 of 26 Posts
