21 - 26 of 26 Posts
2003 Discovery 2 SE7
Discussion Starter #21
@V50_M66 Here is a some feedback from a short trip I took
Black Td5 Thermostat, Hayden HD, Dorman Fan
82 -85 F outside temp
No heat or air running
30 to 55 Mph on the flats 188 -190
60 and above 194
Long idles in park 194 airing up my tires, sometimes 197 in drive after a while at long lights
Long steep climbs off road at low speed, 1st and second gear low range CDL engaged 206 - 208 max speedo not registering too slow
Long steep climbs off road at low speed, 1st and second gear high range 210- 212 max 5 -10 mph
After those climbs if there is a long downhill temp drops to 183- 177 inside of 2 minutes
If there is a long flat 185-188 after about 3-5 minutes at about 20-30 mph
Inline is going in in the next few days - but temps are as expected other than the 210-212 should dropped the CDL in it was a ugly uphill lots of bouncing and traction control. Also right after I had idled for 10 minutes or so airing up.
That's quite consistent with the temps that I see in mine at that ambient temperature. Sounds like my truck is doing what it's supposed to.
  • Like
Reactions: Richard Gallant
very disco
Coolant temps... the more you know about your operating temps the more you worry. I think that’s why LR put the “dial” with the three settings: cold, warm, cooked. Otherwise it would always read hot!
very disco
Lol I was just playing it safe. That was the first word that came to mind...
21 - 26 of 26 Posts
