Brake fluid flush.
Dane, Eric here: I'll be tackling the same project as well. I'm going to be installing new brake rotors, lines, and pads (front and back), shortly. I went with a set of S'S brake lines purchased from British Atlantic, R1 Concepts drilled and slotted brake rotors, and ceramic brake pads. I'll be painting the calipers as well, a nice cherry red. I purchased a pneumatic brake bleeder from Harbor Freight (item #92924), for only $22.00, after the discount. Was reading the reviews, which were pretty good, and decided to give it a try. You have to have an air compressor though. If not, you'll need to do it the buddy system way. Will let you know how it turns out. Will post pictures of the installation, when I start it. Good luck!
