1 - 8 of 8 Posts
hello thought i would try the hill descent mode on an incline near to my new house..... worked awesome but i shouldve just floored it because i got stuck. in the process of rocking it back and forth the ms lights blinked as well as D have reverse and will start going forward high revving it in 3rd. also, i reset the code with a generic scanner. any way i can get it out of limp mode? thanks, Randy:smile
Hi, you erased the fault code but what was it, cos that's the reason for the limp mode and only erasing a fault code from the ECU memory doesnt mean the fault is fixed... it would be nice and cheap to be so simple :serious , the warnings are the result of a component failure not the cause of it... they'll be back soon, the fault code helps you to fix things by telling you whats the problem
  • Like
Reactions: randycanopolis
Was the fault code pointig to it?, read again the fault code and according to it you'll know what's the problem
Then that's what you need to replace
Administrator
Before you go chucking parts at it .... What exactly happened? Di you get it wet? Di you get it good and dirty?
Does the speedo work?
I would clear the codes and possibly do a hard reset and see what changes before.
I had that code a couple years ago and no speedo. As I recall (going back about 4 years) I cleaned and checked some trans. Harness connections and all was good.
Good point cos something is strange about that sensor and the fault code though Land Rover Range Rover SE Discovery II Speedometer Transmitter Genuine STC 4444 | eBay interestingly they named it speedometer transducer while the D2 speedo is working based on VSS signal delivered by the ABS ECU, also if the code was read with a generic OBD2 scanner it's not accurate cos in the description of specific ZF4HP22/24 fault codes P0722(22): * Torque converter slipping = Maintains current gear in low range, limp home mode in high range. Shift pressure to maximum, harsh gear shifts/engagement. so more investigation is needed IMO
1 - 8 of 8 Posts
