Hello,
Just recently moved to Clovis, NM (thanks USAF), which is over 4000 ft above sea level. The truck is running great but is idling a little lower than normal on the first start of the day. Is there a way to tune the carb for idle other than using the choke on the steering column. For example, I own a 65 mustang with a edlebrock carb I installed, on the front are some screws that you can use to adjust your fuel/air mixture to adjust the idle. Is there something like this on the 3.5L V-8 carb for the Land rover?
Cheers,
Andy
Cheers,
Andy
