1 - 4 of 4 Posts
Hi fellas
Eventhough I have the workshop manuals I was wondering if one of you actually knows hoy many Horse Power does the 4-cyl 1.8 cc have?
My freelander is 99 and the model is the SE3.
Thanks for your help buddies
:drink1:
Hope this helps
Capacity 1796cc
No of cylinders 4 in-line
Bore 80mm
Stroke 89.3mm
Compression ratio 10:5:1
Cylinder head material Aluminium
Cylinder block material Aluminium
Ignition MEMS 3.0
Fuelling Multi-point fuel injection
Valves per cylinder 4
Valve actuation DOHC with hydraulic tappets
Maximum power 86kW @ 5500rpm
Maximum torque 165Nm @ 2750 rpm
This is the spec for the 2004 model
1 - 4 of 4 Posts
