1 - 7 of 7 Posts
So I may have a problem. My right rear tire is wearing exponentially faster than all the others on the hard inside. When I sit behind the car the right rear tire looks tone inwardly canted more than the rest. I would not call it extreme but I would call it a potential diagnosis. Had anyone seen something like this? I am taking it in Monday. I am going to have to have a tire! But.... It's an excuse to buy new grabbers. Thoughts?
I have the same issue but it beat up 2 new tires in less than 6 months. Inside on both rears are to the threads. Guessing they didnt do something when I got new tires. I guess ill find out monday....
Well good things about machines is that they are fixable. I need new control arm bushings as well. Love truck but I need to work out some bugs. It sat up for a year bf I bought it in an estate. Pitiful
Control arm bushing are a fairly regular item to replace on this machine. 108k on mine and have done th front 3 times and the back once. It is just a heavy vehicle. I also have to get it 4 wheel aligned yearly to keep it running straight. I do off-road mine pretty hard so frequency of those items will vary depending on how you drive it.
The LR3's are very sensitive to bushing failure and proper alignment. I'm having mine aligned every 6 months no matter what because it's well worth it in the long run. An alignment should basically be like routine maintenance on these things IMO.
1 - 7 of 7 Posts
