1 - 15 of 15 Posts
Why would you want to disable one of the best features of your alarm system, or is it you don't know exactly what super lock does?
Discussion Starter · #4 ·
Tell me Mike, what has happened to countless owners who had a battery go flat while their truck was super locked?
And, I clearly know what super locking does if I quoted this article, just sayin'.
The same thing will happen if you use your standard lock, with a dead battery you still can't unlock or start your truck so I guess, just let your battery go dead.
Computer Nerd
Unless super locked, you can unlock your door with the key, even with a dead battery.
  • Like
Reactions: discovering
Sometimes, though that is a good point. Never had an opportunity to try with a dead battery and unlock the door with a double click, same as when you super lock it.
Discussion Starter · #8 ·
It's something of an open secret that if your battery goes flat while super locked, your sort of screwed. Even jumping the battery from the starter (+) terminal (since you're locked out and cannot open the hood) is 50:50.
There's threads all over all of the LR forums about it, sort of surprised this is news to you.
Hate for this to be one post that I agree with Mike, but when I had mine superlocked and the battery gave up, I started panicing... Stories of having to prise the hood open, break the grill, yank out a headlamp... Luckily a Dweb user pointed out the glaringly obvious that no-one else had thought of (or suggested). All need to do is crawl under, and ground a booster to the trans case, and the other to the starter terminal.
Had the wife push the kefob button - unlocked just fine...
One new battery later, I still have superlock and will probably not bother to disable it. I don't see why unless you have a battery that is well expired and are using just a little charger that can't overcome the internal resistance of the dead battery why this technique wouldn't work... Perhaps that is the 50:50? - 50% use a booster box or jumper cables, the other 50% use a small charger and expect miracles... ??? ... ????
The starter terminal is, after all, conected to the battery via a large cable - same as the ground strap? If you stick enough current on this, it'll power anything on the circuit - or is it some wierd-ass problem of the body controller deciding to not talk to the keyfob because the battery went flat???
This can go on and on but here is a simple idea, quit using super lock.
Dave, in the past I have also recommended to people, who can do what you described without burning up their truck, to do exactly what you have described.
Any way unless you live in a terrible area and are afraid your truck will be stolen, just don't use it.
Huh - you know normally I do my research but 'super locking' got me cold there. I'm thinking "Run away screaming" beats "SOL from dead battery".
Unfortunately, I experienced this and there is absolutely no way of getting in the vehicle if your battery is completely dead not even with the key.
very disco
You just responded to a 10 year old thread. With misinformation.
1 - 15 of 15 Posts
